stoneburner
- 12
- 8
- Athens, Ohio
I've pretty much come to the same conclusion that you did - that the last time i shut it down, it started back up with no problem because it was hot. I've accepted the fact that I will have to tear the engine down, and I am hoping that all of the bearings and internals are still good. I had tried the compressed air trick through the injector port, and got a leak at the bottom of the stroke to where the air was coming up past the pushrods.
I called the machine shop today, and I'm going to have them check the bore, piston, and bearing to see if it's all within spec. If it is, I'll have them rehone the bore ($20) and I'll get a new set of rings and be on my way, If not, i'll have it re-bored to 0.050 over ($50), and pick up a new OE/Yanmar oversized piston and ring set for $32 on ebay. If I end up getting out of this for less than $100 with just a rehone or rebore and new piston/rings, I'll call that a win. If I get out of it for $300 or less, I'll still call that acceptable.
