- 1,122
- 1,079
- 113
- Perry, FL
While running one of my MEP803a's during Irma, it appears unit 2 suffered a catastrophic engine failure. Don't know why, engine had adequate oil and coolant. Any ideas?
Its an ONAN DN4M (technically its a Lister-Petter DN4M... but its being sourced and supported for this application by Onan). What you want is TM-9-2815-253-24 and -24P. See attached.Don't know. Will not crank. Apparently it has internal damage. No connecting rods through block though. Any idea what brand of engine it is? I'm going to start tearing it down later this week.
Thank you very much.Its an ONAN DN4M (technically its a Lister-Petter DN4M... but its being sourced and supported for this application by Onan). What you want is TM-9-2815-253-24 and -24P. See attached.
How much oil.. a little, or a lot? Don't stick your head in the oven just yet. It might be a catastrophic breakdown... it might be something less. Just trying to be positive in this crappy time for youThe engine will not turn over now. Went down on a low oil pressure fault. Oil is coming from somewhere around the front of the engine. Bummed out.
Lister-Petter LPW4Its an ONAN DN4M (technically its a Lister-Petter DN4M... but its being sourced and supported for this application by Onan). What you want is TM-9-2815-253-24 and -24P. See attached.
A noticeable amount of oil. I'll start troubleshooting over the next few days and let you know what I find.How much oil.. a little, or a lot? Don't stick your head in the oven just yet. It might be a catastrophic breakdown... it might be something less. Just trying to be positive in this crappy time for you![]()
You are right... DN4M is what Onan calls it only. ThanksLister-Petter LPW4
