MILITARY VEHICLE, CARRIER, CARGO TRACKED, 6–TON, M548A1, 2350–01–096–9356, M548A3 2350–01–369–6081
Guyfang
28,630
Burgkunstadt, Germany
Any information printed in Red, is not allowed to be posted in the forum, due to the TM Classification, or simply can not to be found.
A big thanks to @drspooks and @jasonjc for several of these publications!
Guyfang
28,630
LO 9-2350-247-12 Lubrication Order dated 1994
CARRIER, CARGO TRACKED, 6-TON: M548A1-2350-01-096-9356
CARRIER, CARGO, TRACKED, 6-TON: M548A3-2350-01-369-6081
CARRIER, ELECTRONIC WARFARE SYSTEMS, TRACKED, 6-TON: M1015A1-2350-01-136-8745
TM 9-2350-247-10 dated 2001 wc#1
TECHNICAL MANUAL, OPERATOR'S MANUAL FOR: CARRIER, CARGO TRACKED, 6–TON
M548A1 2350–01–096–9356
TM 9-2350-247-20-1 dated 2001 wc#1
TM 9-2350-247-20-2 dated 2001 wc#1
TM 9-2350-247-20-3 dated 2001 wc#1
TECHNICAL MANUALS, UNIT MAINTENANCE MANUAL FOR CARRIER, CARGO TRACKED, 6–TON,
TM 9-2350-247-24P dated 2003 wc#1
UNIT, DIRECT SUPPORT, AND GENERAL SUPPORT MAINTENANCE, REPAIR PARTS AND SPECIAL TOOLS LIST
(INCLUDING DEPOT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LIST) FOR:
CARRIER, CARGO, TRACKED, 6-TON: M548A1 (2350-01-096-9356)
CARRIER, CARGO, TRACKED, 6-TON M548A3 (2350-01-369-6081)
TM 9-2350-247-34 dated 2001 wc#1
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL, FOR THE
CARRIER, CARGO, TRACKED, 6–TON,
TM 9-2350-247-10-HR dated 1978
HAND RECEIPT MANUAL COVERING BASIC ISSUE ITEMS (Bll), AND ADDITIONAL AUTHORIZATION LIST (AAL)
FOR CARRIER, CARGO TRACKED, 6-TON: M548
NATIONAL STOCK NO. 2350-00-078-4545
TM 9-2350-247-PCL dated 1990
COMBAT VEHICLE, PRE-COMBAT CHECKLIST FOR:
CARRIER, CARGO, TRACKED, 6-TON (2350-00-078-4545
Guyfang
28,630
TM 9-2815-205-24 dated 2013
TECHNICAL MANUAL, FIELD AND SUSTAINMENT MAINTENANCE, FOR 6V53/6V53T ENGINES, DIESEL WITH CONTAINERS
MODEL 5063-5299
NSN 2815-00-124-5390
NSN 2815-01-295-7458
MODEL 5063-5392
NSN 2815-01-246-0903
MODEL 5063-5393
NSN 2815-01-248-7644
MODEL 5063-539L
NSN 2815-01-412-2715
TM 9-2815-205-2P dated 2013
TECHNICAL MANUAL, FIELD AND SUSTAINMENT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LIST (RPSTL) FOR 6V53/6V53T ENGINES, DIESEL WITH CONTAINERS
MODEL 5063-5299
MODEL 5063-5392
MODEL 5063-5393
MODEL 5063-539L
Guyfang
28,630
TM 9-2520-238-34 dated 2001
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE MANUAL FOR:
RIGHT ANGLE DRIVE, COOLING FAN M113A1 FOV, M113A2 FOV — 2990-00-712-1280
M113A3 FOV — 3010-01-318-5670
GEARCASE, TRANSFER
M548, M548A1 — 2520-01-047-8613
SERVICE GEARCASE — 2520-01-087-0156
M113A1 FOV — 2520-00-572-8605
M113A2 FOV WITH 100 AMP GENERATOR — 2520-01-061-5570
M113A1 FOV, M113A2 FOV WITH 200 AMP GENERATOR — 2520-01-362-8589
DRIVE ASSEMBLY, FINAL
M113A2 FOV, M113A3 FOV — 2520-01-061-5766
M548, M548A1 — 2520-01-067-8933
DIFFERENTIAL, STEERING CONTROL
M113A1 FOV, M113A2 FOV, M548, M548A1 — 2520-00-714-6135
BRAKE, SINGLE DISK
M113 FOV, M548, M548A1 — 2530-00-088-9866
CYLINDER ASSEMBLY, HYDRAULIC BRAKE
M113 FOV, M548, M548A1 — 2530-00-679-9169
TM 9-2520-338-34P dated 2001
DIRECT SUPPORT, AND GENERAL SUPPORT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LIST
(INCLUDING DEPOT MAINTENANCE REPAIR PARTS AND SPEICAL TOOLS LIST) FOR:
GEARCASE, TRANSFER
BRAKE, SINGLE DISK
TM 9-2520-254-34 dated 1971
T E C H N I C A L M A N U A L, DIRECT AND GENERAL SUPPORT, MAINTENANCE MANUAL
TRANSMISSION, AUTOMATIC, 2 5 2 0 - 0 6 6 - 4 2 4 0 (ALLISON DIV., GMC MODEL TX 100-1)
TM 9-2520-254-34P dated 1989
T E C H N I C A L MANUAL, D I R E C T S U P P O R T A N D G E N E R A L S U P P O R T M A I N T E N A N C E R E P A I R T O O L S L I S T ( I N C L U D I N G P A R T S A N D S P E C I A L T O O L S L I S T ) F O R:
T R A N S M I S S I O N , A U T O M A T I C , E N C A S E D I N F O A M , 2 5 2 0 - 0 1 - 1 2 0 - 2 1 6 9
T R A N S M I S S I O N , A U T O M A T I C , W / C O N T A I N E R , 2 5 2 0 - 0 1 - 1 3 3 - 9 2 2 7
( A L L I S O N T R A N S M I S S I O N D I V . , G M C M O D E L T X 1 0 0 - 1 )
TM 9-2520-272-34&P
TECHNICAL MANUAL, INTERMEDIATE, DIRECT, AND GENERAL SUPPORT MAINTENANCE MANUAL
(INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST) FOR:
CROSS DRIVE TRANSMISSION W/CONTAINER
MODEL X200-4 & 4A
NSN 2520-01-201-4784
NSN 2520-01-397-1074
ALLISON TRANSMISSION
DIVISION, GMC
Guyfang
28,630
TM 9-2920-257-30&P 1987 wc#1
TECHNICAL MANUAL, DIRECT SUPPORT, MAINTENANCE MANUAL (INCLUDING REPAIR PARTS AND SPECIAL TOOLS) FOR:
GENERATOR, ALTERNATING CURRENT,
200 AMPERES (Leece-Neville)
NSN 2920-01-147-1575
NSN 2920-01-238-9710
AND
200 AMPERES (Niehoff)
NSN 2920-01-292-2993
NSN 2920-01-298-8072
Guyfang
28,630
TM 9-2920-225-34 dated 1981
TECHNICAL MANUAL, MAINTENANCE, DIRECT AND GENERAL SUPPORT LEVEL, GENERATOR ASSEMBLY
PRESTOLITE MODEL AMA-5102UT, NSN 2920-00-909-2483
LEECE-NEVILLE MODEL 3002AC, NSN 2920-00-909-2483
LEECE-NEVILLE MODEL 3002AD, NSN 2920-00-909-2483
LEECE-NEVILLE MODEL 3002AE, NSN 2920-00-909-2483
LEECE-NEVILLE MODEL 5504AA, NSN 2920-00-475-1446
LEECE-NEVILLE MODEL 5504AB, NSN 2920-00-475-1446
LEECE-NEVILLE MODEL 2184AC, NSN 2920-00-782-1955
LEECE-NEVILLE MODEL 5300GP, NSN 2920-00-818-8635
TM 9-2920-225-34P dated 1974
TECHNICAL MANUAL, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS LISTS (INCLUDING DEPOT MAINTENANCE REPAIR PARTS AND SPECIAL TOOLS)
GENERATOR, ENGINE ACCESSORY (ALTERNATING CURRENT)
PRESTOLITE MODEL AMA-5102UT (FSN 2920-909-2483)
LEECE-NEVILLE MODELS 3002AC AND 3002AD (FSN 2920-909-2483) 5504AA AND 5504AB (FSN 2920-475-1446) 2184AC (FSN 2920-782-1955) 5300GP (FSN 2920-818-8635)
Guyfang
28,630
TM 9-2540-205-24&P dated 1992
Technical Manual, Organizational, DS, & GS Maintenance Manual for Heaters, Vehicular Compartment:
STEWART-WARNER
1056OC24 (NSN 2540-01-063-0691)
10560M (NSN 2540-01-071-0651)
10560M24B1 (NSN 2540-01-169-5159)
10560G (NSN 25404)1-262-6013)
HUPP
MF510B (NSN 2540-01-071-0652)
MF510C, MF60B-24V (NSN 2540-01-162-3834)
MF60A-24V (NSN 2540-00-930-8838
ESPAR
V7S (NSN 2540-01-114-7688
TM 9-2540-207-14&P dated 2007
TECHNICAL MANUAL, UNIT, DIRECT SUPPORT AND GENERAL SUPPORT MAINTENANCE, (INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST) FOR:
HEATER, VEHICULAR COMPARTMENT, NSN 2540-01-396-2826, MODEL A-20
Guyfang
28,630
TM 9-4910-571-12&P dated 1984
TECHNICAL MANUAL, OPERATOR'S AND ORGANIZATIONAL MAINTENANCE MANUAL, INCLUDING REPAIR PARTS AND SPECIAL TOOLS LIST , SIMPLIFIED TEST EQUIPMENT FOR INTERNAL COMBUSTION ENGINES
( NSN 4910-00-124-2554
Guyfang
28,630
TB 9-2350-368-25 dated 2003
FABRICATION AND OPERATION O F POWER PLANT TEST STAND, M113A2/M113A3/M548Al/M548A3 FAMILY OF VEHICLES INCLUDING OPPOSING FORCES SURROGATE VEHICLE (OSV), HEADQUARTERS, DEPARTMENT OF THE ARMY, Washington
TB 9-2350-369-20-1 2007
TECHNICAL BULLETIN, INSTRUCTIONS TO CONVERT T130E1 TRACK TO T150F TRACK USING KIT, 57K4269 (2530-01-502-3401) ON:
M113A3 FOV CARRIERS
M113A2 FOV CARRIERS
M548A1/A3 CARRIERS
AND OSV/MBT VEHICLES
Guyfang
28,630
TM 9-2350-275-BD dated 1984 wc#1
TECHNICAL MANUAL, O P E R A T O R S , O R G A N I Z A T I O N A L , D I R E C T S U P P O R T A N D
G E N E R A L S U P P O R T M A I N T E N A N C E, BATTLE DAMAGE AND REPAIR F O R THE M 1 1 3
F A M I L Y, CARRIER, PERSONNEL SELF-PROPELLED, FULL-TRACKED
