First I need to thank JT, rlwm211 for their technical knowledge & advise which proved invaluable.
Thank you both..so much..
Since day one I always thought my valves sounded a bit noisey. Talked it over with JT on a couple occasions and he had a deuce that was the same way, yet ran beautifully, as does mine.
He suspected there was some sort of harmonics happening in the valve train at certain RPM's that would cause the valves to be a touch noiser than at other times. It made sence to me too and after playing with the RPM's on a few trips it sorta proved to be the case.
Well I've got a trip coming up shortly, so I thought I'd check the adjustment to be on the safe side and see if it makes a difference.
Now the way they explain how to do the adjustment in TM 9-2320-361-34, page 3-26 may be a bit confusing to some at first. Reading it over a few times will make it clearer and certainly the easiest way to do the job.
Now the TM has you removing the radiator so you can turn the engine over using the bolt on the crank balancer. I wasn't about to do that so after talking with my mentors it was decided to go to plan B. That would be using a rear wheel or turning the driveshaft with a bar in the U-joint.
I tried the tire thing and I couldn't make much headway. So next I jacked up the rears and put the transfer case in 'low' and the trans in 5th. gear, much better. Again after confering with a mentor, it was decided it may be even better to put the tranfser case in 'high' with the trans in 5th., better yet. I still didn't care for the bar in the U-joint thing so I got out a 24" pipe wrench and used that on the driveshaft right behind the T-case....BINGO....easy as pie!!!
Now whats next is to turn the engine over till the first valve rocker (intake) on the first cylinder (#1) is all the way down (valve open) to start adjusting.
***IMPORTANT SAFETY MESSAGE***
FIRST OFF...disconnect your batteries and put something on your fuel shutoff handle to hold it all the way out till your done with the job!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
So now your able to adjust about half the various valves. The TM calls for .010 gap on the intake and .025 gap on the exhaust. Those with decades more experience than me recommend .015 gap on the intake and stay with the .025 gap on the exhaust and that's exactly what I did.
Then, after the proper valves are adjusted, you turn the engine over 1 full turn (360*) till the front rocker on #6 cylinder is full open and proceed to adjust the remaining valves. It's just that simple and only requires you turn the engine over 1 time to adjust all the valves.
Couple bits of info in case yer wondering.....
*cylinders are numbered 1 thru 6 starting at the front
*front valves are intakes, back are exhaust on all cylinders
*lock nuts on the rockers are 9/16", but I found a 14mm box end wrench worked best.
*rocker cover gaskets are thick rubber. Use some dielectric grease on them when you reinstall or replace them and they will seal better plus never stick.
*whole job start to finish, minus BS sessions, took 1hr. with two people. 1-on top adjusting/ 1-underneath turning it over.
This weekend I'll have it out to see how it sounds on the highway, couldn't really notice a difference sitting in the shop running. Because of the different setting I had to adjust all the intakes, but only three of the six exhaust needed adjustment and they were too tight.
This motor has 26k on it since it's Tooele rebuild in 1991 and this is the first the covers were off.
The valves are something that needs to be kept up with on these motors to help them last. I found this to be a very easy thing to do if you follow the TM's directions.
![Thumbs Up [thumbzup] [thumbzup]](https://www.steelsoldiers.com/images/smilies/icon_smile_thumzup.gif)
