I only checked and cleaned the regulator, it seems fine when running.Do you tune those voltage regulators? I've heard that's a lost art and solid state is the way to go.
I'll let you guess.What is that, some kind of alarm buzzer or horn?
Low air pressure.I'll let you guess.
Here it is back up, it should work now.
I was wondering about that. I've never actually seen the low air pressure buzzer on my truck. Makes me wonder if it looks like that one.Low air pressure.
Not sure solder will fix it. I think that is made of "pot metal" that is cast. A high temperature epoxy might be a better choice. Let us see if more experienced minds will speak up on the subject.Like the cylinder head, the oil cooler was also deteriorated by frost.
I will try to solder it.
