ltdaniel
- 14
- 3
- Three Rivers, Ca
I just had the trans rebuilt after the shaft into the 3rd 4th gear planetary sheared all the teeth of the input shaft. New part including new production clutch plates throughout. The truck also has the Reb Shifter. I had drove the truck over 3000 miles before failure.
My problem is after putting oil (Dextron III) into the trans and getting the fluid coupling and the underdrive unit full of fluid It only shifts into reverse, it does not shift into drive.
I can't even feel it engage 1st gear.
I have gone thru the linkage adjustment per the manual, and I still can't feel it engage into drive.
Any ideas would help.
Thanks
Dan McCluskey
Thanks
Dan McCluskey
