No, you got air in the system. Remove dog house and crack the injector on passenger side of the head have someone crank it while you crack open the injector nut till you see fuel coming out. It should start back up after you do this!Just removed the line from the fuel pump at the filter - no fuel. Was it a coincidence it stopped running as I cracked open the drain valve? hmmmm
If you open the fuel filter drain valve while running and it sucks in air and dies then ether the lift pump is bad or there is a problem with the suction line to the tank, a stuck check valve or a plugged fuel tank pickup sock, besides this thread is about 8 years old, I hope the OP has figured it out by nowNo, you got air in the system. Remove dog house and crack the injector on passenger side of the head have someone crank it while you crack open the injector nut till you see fuel coming out. It should start back up after you do this!
I'm confused here on the bad "Lift Pump", IF the vehicle is running and driving around, but you bleed the fuel filter drain valve and it shuts off, how is the LIFT PUMP bad? It has been running until i hit the drain valve. Hope that makes sense......If you open the fuel filter drain valve while running and it sucks in air and dies then ether the lift pump is bad or there is a problem with the suction line to the tank, a stuck check valve or a plugged fuel tank pickup sock, besides this thread is about 8 years old, I hope the OP has figured it out by now![]()
That's a nice set up. Where did you tie into the fuel line? before the injector pump? Great idea!!!I also installed a fuel pressure gauge, maybe next time I will get a warning of some kind
The IP has a charge pump built in, if the lift pump is bad the engine can run with only the charge pump pulling fuel from the tank, it usually will have low power but it still can be started and run, but when the flow is stropped by opening the drain valve and allowing air in it is normally very hard to get the flow started again.I'm confused here on the bad "Lift Pump", IF the vehicle is running and driving around, but you bleed the fuel filter drain valve and it shuts off, how is the LIFT PUMP bad? It has been running until i hit the drain valve. Hope that makes sense......
I have NOT removed any check valves. She starts every time and runs fine. Doesn't seem to be starving from fuel. Sorry, what is the "IP" ?The IP has a charge pump built in, if the lift pump is bad the engine can run with only the charge pump pulling fuel from the tank, it usually will have low power but it still can be started and run, but when the flow is stropped by opening the drain valve and allowing air in it is normally very hard to get the flow started again.
This can also be a bad check valve, have you removed the check valves yet?
So to farther elaborate, if the lift pump is bad and the charge pump in the IP (injection pump) is pulling fuel, then all of the fuel "delivery" system has a vacuum on it including the filter, so if you open the drain valve and no fuel comes out you should immediately close the valve because the IP is now pulling in air instead of fuel.
Ok, gotcha!! That helps a lot man!! Thanks again!When you change the lift pump you MUST insure the push rod is pushed up into the block, there are two common ways to do this.
I remove the two 1/4" screws from the plate behind the pump and remove the plate and rod and coat the rod with grease and push it back into the block, put the plate back on and install the pump.
Others use something to reach in at the same time as installing the pump and push the rod back in the block, I have enough trouble doing one thing at a time let alone two.
Any simple way of checking the check valves?There are also two check valves, one each in the suction and return fuel lines just ahead of the fuel tank, these can be troublesome.
Most folks just remove them and replace them with a piece of fuel hose, they are installed with two short pieces of fuel hose each from the factory so removing them is rather easy.
IIRC one hose is 3/8 and one (return) is 5/16
You can bolt the pump up with the rod out of place, this almost always breaks the rod and or damages the pump.Ok, gotcha!! That helps a lot man!! Thanks again!
My Lift Pump should be here on Thursday. I guess it's still ok to drive if needed as i have been all this time, lol
Ok, i should be able to see this Lift Pump ROD? and whether or not it's installed correctly, right? Last thing i want to do is break something else, lol....i searched u-tube on humvee Lift Pump installation and nothing coming up. I'd rather be prepared and spare any guessing.You can bolt the pump up with the rod out of place, this almost always breaks the rod and or damages the pump.
If you cannot get fuel out of the drain when running I would not get too far from home until you get it fixed.
You can disassemble the check valves, clean them and re-install them, but they are not needed and like I said most just immediately remove them when they get their trucks, they do put more strain on the lift pump as it has to pull hard enough to unseat the check valve.
Mogman, THANK YOU very MUCH for all this information, man!!!! I owe you a cold beer!!! lolIt is easy to see when the pump is removed, it will fall as far as it can out of the block, the small plate behind the fuel pump prevents it from falling out.
It is however fairly difficult to get something under the end of the rod and push it back into place at the same time you are installing the pump basically handing the end of the rod over to the pump arm without dropping it, that is why I just remove the plate and grease up the rod so it stays in place.
The gasket behind that plate is the same used on SBC and BBC (chevy) motors from the 70s so you can go to any parts house and get this gasket, just specify say a 1970 chevy with a 350 gasser engine.
This is what it looks like.
It is hard to see the rod when installing the pump, why I do it the way I do, but others have been successful without removing the plate.Ok, i should be able to see this Lift Pump ROD? and whether or not it's installed correctly, right? Last thing i want to do is break something else, lol....i searched u-tube on humvee Lift Pump installation and nothing coming up. I'd rather be prepared and spare any guessing.
