choll
- 5
- 18
- Las Vegas,NV
Greetings everyone
Its been a while since I have been here, took the 09 off the road for about 2 years as I got struck with the humvee fever. Any way two months ago I put the 09 back on the road to do a 1400 mile road trip with it. I drove it about 1200 miles to get any bugs worked out before I decided to drive from NJ to New Orleans no issues to talk about until 150 miles from NO.
The truck started to over heat and there was antifreeze everywhere, I assume from driving 65mph.
Any way I can not pinpoint where it is coming from so I add water and continue to New Orleans. When I get to hotel I start going over everything. Im thinking blown head gasket, the is no water in the oil. I add water again and the cooling is working fine until I need to add water again. I see coolant leaking from the overflow because of a crack in plastic. there is no coolant in the valley or coming from water pump.
When I look in the overflow the coolant is moving with slight bubbles. After the motor cools when I look in the radiator, the coolant is low about a quart. When I open the radiator cap you can hear the pressure release. So with the pressure still in the rad 8 hours later what are every ones thoughts. Im still thinking head gasket but I cant see a leak or drips coming from the motor anywhere
