- 1,172
- 31
- 48
- Galesville, WI
The lift is only about 4-5 feet. Problem is the pump was made for pumping fuel from above ground tanks and not water from creeks and ponds. The pump is an impeller pump with an aluminum impeller and pump body (non-sparking). Even though not its intended design, it will do what I want. It will eventually wear out, fortunately I have 2 and paid $63 each
As far as you Firemen go, I appreciate your input and thank you for serving your communities. Most people do not realize the time and energy it requires and the life changing events you face and how those events impact you.
