jvrotter
- 4
- 18
- yucca valley, ca
I want to install a water can holder in the back of my M1009 on the corner bracket in the cargo area. Does anybody know what size bolt that the four threaded holes take?
I assume you meant 3/8-16, that would be a standard coarse thread... 3/8-18 is a taper tap for 3/8" pipe threads.OK, I double checked the threads and a 3/8-18 is the correct bolt.
Depends. Not all can mounts are created equal. The strap can either be anchored to the mount itself (see picture), or loop underneath and around it, with the bolted down mount holding the strap in place.Does anyone have a good detailed pic showing how the hold-down strap mounts?
