Rear Driver Side Injector Replacement Tips
texorcist
Texas
Successfully removed all other injectors except rear injector on driver side.
The shifter off the steering column is blocking my 30mm socket. Wanted to see if anyone had a tip for removing that one and putting in its replacement.
Barrman
2,379
Giddings, Texas
I have removed all of them without issue on several trucks in the past. However, I can not remember if I used the socket, a combination wrench or something else.
Have you tried moving the shifter to maybe get clearance?
