Zoidsfan77
- 1
- 8
- Columbus, Ohio
Greetings friends!
Forgive me if this has been covered before, nothing on the topic came up in my searches.
The rear-front axle on my M814 will slide left and right in corners. It shifts on the leaf perches. I can hear a clunk when it happens. I can also see when driving strait the sidewall of the tires in or out farther than the rear-rear. Total travel is about 1 inch. The truck has not always done this, but has been doing it for the last few months.
There are fresh scrape marks where the perch and leaf slide. The perch has NOT moved on the axle.
So my question: is this normal? I was thinking perhaps it was designed to slide somewhat? If so should I lubricate the surface?
Or am I missing some sort of spacer, bushing, etc.? None of the other perches have any additional hardware, and appear the same with the exception of the slide marks.
Thanks for your wisdom!
