rustystud
- 3,487
- 113
- Woodinville, Washington
I just want to say one more thing about the FDC and it's function. Think of it as a "voltage drop" compensator. If you have a long electrical cable you will end up with voltage drop across the ends. So what the FDC does is build in a compensation for this voltage loss. Just like copper has one resistance per foot and aluminum has another so does gasoline compared to diesel fuel. So at a given pressure and flow of fuel we will have a different "resistance" for gasoline compared to diesel fuel. Since diesel fuel has more BTU's of energy compared to gasoline it will get a higher resistance to bring it down to the gasoline's level. This is one reason most people just eliminate the FDC completely. That and the fuel leakage problem.
Now as to how much movement the stop plate has, I don't have an answer. But I do plan on making my own tester later on and then I can determine if and how much movement there really is.
I know I have been a little testy answering some questions here. The reason is I did not want this thread to degenerate into an argument session. It was to be a stand-alone rebuild thread that I hoped could be sealed and put into the stickies. In fact I was hoping the moderators could go back to post #98 and delete everything after that and then seal this thread.
Then if anyone wanted clarification on any pump matter they could start a new thread and all discussions and arguments could be held there.
