Roll painting a CUCV
detroitdiesel4x4
Piney Hicks N.J
Since I could say we didn't start off on a good note :p, I figured it was time to redeem myself. After I fix my rockers, and get few body blemishes worked out I was planning on repainting my cucv as the current paint is pretty faded (looks good in the rain). I was reading about people having good luck with Gillespie aerosol cans, but was wondering if anybody has tried rolling paint on. I've had that recommended to me a few times on previous trucks I've painted, and after seeing a few they didn't turn out too bad. Assuming my camouflage is the correct pattern I planned on just scuffing with 220ish grit, and smoothing with 800-1000 grit, and then masking and rolling. Any reason I should stick with the spray gun as opposed to a roller? On a side note, I like the look of distinct edges rather then that overspray look where the colors meet.
doghead
4 Star General /Moderator
1,196
NY
Have you seen the threads on using house paint?
There are a few of them, some give the mix codes for Lowes and Homedepot.
1,831
Search the term Behr in the CUCV forum then in all forums. You will find lots of great info and loads of pics.
4-64 Armor
Nashville, Indiana
I remember applying camo colors with a paint brush on new M151A2s when I was in Germany... I remember thinking "Wow, I'm painting over this new O.D. with a paint brush! what a shame!" ..... I think I'm going to use a spray gun and paint my M880 with some Majic olive drab from Rural King.:-D
494
23
Weidman, MI
No need to redeem yourself. It is most of the others in the other thread that could stand to do so. That was ridiculous And a friendly caution from someone else that seems to take a lot of wrath around here, be very careful about asking any questions that may have been covered elsewhere. 'Nuff said.
Mike
hndrsonj
Senior Chief/Moderator
362
Cheyenne, WY
If its CARC, i'd use something rougher than 220. You'll be there forever.
camogriz
Carmel, NY
I used the Behr paint formula I found here to paint my hood with a roller. It is not as smooth as it would be using a sprayer, but it was easy. I did follow up and used spray paint to add the flat black camo pattern. I think it came out amazing. I am waiting for warmer weather to keep going.IMG_0179.jpg
