Hi All,
I'm going through a complete brake system re-do on my truck. Bought all new parts for almost everything, trying to ensure that it is as safe as can possibly be.
I have run into an issue however, and I might need a few ideas. After loosening the 1 1/8" nuts on the adjusters for one of my wheels, and attempting to turn the 1/2" major adjuster to properly space the shoes, I have ended up almost nearly rounding the 1/2" adjuster. I'd like to avoid having to completely take the wheel apart again if possible.
I'm unsure as to why yet, but after putting new shoes on and getting the hub and drum back on, the bottom adjusters simply won't turn. I had no problem with them on one wheel, but this one won't budge.
I'm considering possibly filing it back down to get a good grip on it, but this still won't help much if I can't turn them. My 2nd idea would be to heat them up with a propane torch and then attempt turning. It still seems rather odd that they won't turn with the amount of force I put in.
for the remainder of my wheels, I'm considering removing the bottom eccentric adjusters completely while I have the hub/drum off, then cleaning/putting a little grease on them. Is it possible to completely remove them? If so, does anyone have any recommendations?
