dmilkman589
- 1
- 18
- troy, ny
where is the injection pump check screw or what ever its called located. and what is it for??? im having smoking problems. i figured id start there..
The so called check valve (housing pressure regulator valve) on the front of the injection pump looks like a pipe nipple. It is right next to the pink wire. The internal valve is a glass ball. When pumps begin to fail, the valve plugs with debris and a band aid fix is to knock the glass ball out of the valve.ok so i found the injection pump return valve or where its suppose to be. there isnt one. there is just the nipple for the hose to go on . no valve. the nipple screws right into the pump. is that bad???
