Soften M1123 suspension
Mk23
81
Port Angeles, WA
How can you improve the ride on the M1123? It's got the 3000lbs, springs correct? Can you put softer springs in, like the 1250lbs ones? Or even the 954lbs ones? Would spacers be needed to maintain ride height?
Can anyone please point me in the right direction? My google-fu is letting me down this morning. Thank you
REF
135
Porterville Calif
My M1123 is an extended capacity unit, swapped in a set of rear variable rate springs 12342616, 5360-01-357-2413. bolted right in with vary little to no change in ride height.
I left the front springs alone. rides much better now. I run around unloaded most of the time and with no weight in the back the rear suspension with stock springs hardly moved (based on shock travel) now the rear suspension moves. I would do it again.
Yours may have the variable rate springs already some M1123's did, just take a caliper and measure the diameter ( size of the round steel it's made of) of your bottom coil, as you move up the spring the coils will get smaller on the variable rate spring.
hope that makes sense to you.
good luck
Mk23
81
Port Angeles, WA
Thank you for the lead and the part Number! I googled some pics and I can see what you mean about the shape of the spring. I will check mine out and see what I have.
Any upgrades available for the Shocks? I know the GMV used Rod Hall shocks, are those available? Do they improve the ride, or is it mostly for desert woops...
REF
135
Porterville Calif
To be honest, I haven't pushed mine hard enough in the desert yet that shocks have been a problem. The stock shocks have worked well for tooling around town and off road. I have not driven off road fast enough yet and worked the suspension hard enough to have any issues. Now if I put a ton or more in the back and try running the desert at 45MPH or more I would expect the shocks to heat up.
That being said;
If you find shock that work for you please let us know what they are.
Mogman
10,887
Papalote, TX
I read somewhere that the Moog 81085 springs for some model Nissan work great in the rear of a light HMMWV, anyone else heard of this?
86humv
567
Texas
If you put variable rate springs in the back...you also need the upper cast iron mounts.
Mogman
10,887
Papalote, TX
WELL.... they are MOOG parts, the MOOG springs are constant rate.
Retiredwarhorses
4,914
Brentwood, Calif
most m1123’s had the non-variable rate spring MWO applied due to MAK.
you would need to install 954lb fronts and variables in the rear to get it back to pre-MAK.
Mk23
81
Port Angeles, WA
Thank you. Yes, my 1123 did have MAK applied
I just received the variable rear springs and plan on putting those in.
Is 12338316-1 the correct part number for the 954lbs front springs? If yes, any idea who might have them in stock?
Retiredwarhorses
4,914
Brentwood, Calif
make sure you have casted rear spring uppers...most m1123’s have the old style.
Crapgame
359
Emerald Coast FL
For Nissan Armada SUV? Approx 207inches long, 79 inches wide, GVWR 6800-7100lbs, 9000lb tow capacity. The springs soften the road contours while the shock absorbers reduce the body bouncing on the springs.
For about $130/pair I suppose it couldn't hurt to try, other than the physical effort to change the rear springs.
I'm in the same boat on a 1994 M1097A1, would like a softer ride to preserve my spinal discs and dental fillings.
coolboatguy
35
las vegas
I came up with this. It works. But I have a lighter vehicle m998. I also used the 1" daystar spacer cut down a 1/4" to give me a 24" ride height hub to fender.
SMP2010
Murrieta, CA
How did you cut down the spacer? And do you have any part numbers you can share? I also have a M998. Did you leave the stock springs in front?
coolboatguy
35
las vegas
I used a router personally but you could use a table saw, reciprocating saw or even just leave it. The router allows you to ease the inside corner of the spacer to fit over the lip of the mount. The spacer has a flat bottom and mount has a lip.
I have since upgraded to coilovers in the front. I like the adjustability of spring swaps, and shock valvings. If someone was to do this I would suggest do the rears first. Then decide what they want with the fronts.
daystar KN09103BK
SMP2010
Murrieta, CA
daystar KN09103BK
Thank you. What about springs, do you happen to know the Moog part number? is it 81085 as mentioned above?
