M1009 - Stock set up, all new belts.
My question is this: All warmed up, she doesn't squeal. If I start her after she has been sitting for a while, or over night, in any weather, I will get belt squeal. Now, here is the quicker. They only squeal while the alternators are charging and the glow plugs are in cycle. Once the glow plugs finish up, the squealing stops. Could be 70 degrees or 20 degrees, the squeal is there, it just last longer in the cold and only while the glow plugs are doing their thing. The belts are pretty tight and it did it when I had the old ones on and does it after the new ones were put in.
Is this normal? Is there anything I can do to eliminate this?
Thanks.
Thanks.
