yeah that makes sense, the different strengths and all, I will give that a whack. Now I just need a day off to try my hand at the helicoil job....I usually use the red type installing a HC... and blue going in with the bolt AFTER the other cures.
Did you use JB weld to repair it?Has anyone noticed how a 6.2 will Kick Back sometimes when trying to start? I think this is what causes the bolts to Break. I got a truck where the Corner Ear broke off the Block. I was able to repair it and ran it a few years. There is Lots of Tourque in these starters . I think Timing on the motor may be a factor on some of these vehicles.
Got a part number for that gear reduction starter?Its easy... just use tape to mark your depths on the drill bit.
I seriously think I would just try a new starter first if the bolts are grabbing...
Got a part number for the secondary filter? I have a spare Stanadyne for the main filter, so I will swap that out.It could be the ip. in my experiance they do not fail without warning, ie lack of acceleration or air in fuel symtoms , or leakage. You were right to check fuel pressure and ip solinoid. I would check glow plugs because it is so easy, and mabey they got fried, even though you figure the engine is warm. I guess you could make sure there is no water in fuel. There is a secondary fuel filter under the intake manifold. I doubt it is the problem, but if you suspect your fuel supply you should replace both filters. You may not need to, but if you replace secondary fuel filter you can by unbolting vacuum diapham from vacuum pump to get at filter. you do not need to remove vacuum drive, which is a bitch to get back in. It is hard to help over the computer, . I understand your frustration. Good luck.
