You could blow out a seal or gasket very easily like that. even with only a couple of psi. IMHO, you would be better off taking a chance on getting a little water in the diffs. If you blow out a pinion seal, it will leak at speed and could burn up a third member, wheel bearings, etc.thinking about that and the vents could always run line from the vents to the air system and put the axle under positive pressure when fording not much pressure would be needed.
Read the tm on the fording system. Might be suprized......You could blow out a seal or gasket very easily like that. even with only a couple of psi. IMHO, you would be better off taking a chance on getting a little water in the diffs. If you blow out a pinion seal, it will leak at speed and could burn up a third member, wheel bearings, etc.
I actually lol'd at that one.OMG, theres a hurricane coming and I never read my TM...
