quickfarms
- 25
- 48
- Orange Junction, CA
Is anyone else having an issue with tapatalk not connecting to this site?
Did that but tapatalk search can not find steel soldiers.Nope. Uninstall and reinstall and it should work.
I am using verizon on a iPhone 5s with the current operating system.It's listed simply as steel soldiers. However, what network were you connecting with? What is your web facing IP address?
I had an issue all day yesterday as well
The only way you'll cure it is if you send me your web facing IP address. Otherwise you'll not be able to use tapatalk.I am using Iphone 5 on verizon also. Tapatalk aint working here either. Of course with all the daily festivities, I probably wont have time to experiment. When you find a cure, Post it..
Thanks
-FLASH-
I understand. It's not this site. It's all of them i go on. Oh well. Keep up the good work.If it's an issue with connecting at all, there's a possibility that security system I've implemented might be blocking it. But if it's just slow, I have zero control over cell coverage, data speeds, device speeds, exc.
