RTFM. 1-3 ohms.
I sure wish people would post when they actually knew what they were talking about.
Say it with me, "There is no reason to worry about a cascade failure!"Ohm tested all 8 glow plugs and found 3 to be completely open.
They were just playing "follow the leader"Say it with me, "There is no reason to worry about a cascade failure!"
Yep. Just use an ohmmeter. Do not have the resistors connected to the batteries when you test it. You'll need a good quality ohmmeter.A little off topic but still on CUCV glow plug system. Is there a way to test the resistance of the double resistor that cuts 24v down to 12v to fire the glow plugs?
John,Is there a way to test the resistance of the double resistor that cuts 24v down to 12v to fire the glow plugs? JT
Unfortunately I will not be going to the Redball meet this weekend.Karl, as always, thank you. I had tried an ohm meter earlier, thought I needed 6 ohms and got confused. If you are coming to Redball meet at MT Bethel, PA this weekend, can you bring your ohm meter and I will bring resistors down. JT
I would like to test my resistors, but I am unsure as to how to accomplish this. I have several multi-meters, but that doesn't mean I am well versed as to how to use them. There are many settings on each meter and I don't know what they all do. If I understand this thread correctly, I should disconnect the resistor pack from the 24V buss bar on passenger side fire wall. Set my meter to "Ohms", then put a probe on each end of one resistor (the top resistor, for example). My meter should give a value that indicates the resistance between the probes. is this correct? Please advise....Yep. Just use an ohmmeter. Do not have the resistors connected to the batteries when you test it. You'll need a good quality ohmmeter.
Thank you sir!!!! I have copied this information and I put it in my binder. I wonder if I should take the time to test my new glow plugs. Once I put the new plugs in, my truck fired right up. I have begun to realize that I am my CUCV's worst enemy. All this time I thought I was doing everything right, but I still manage to kill my truck and blazer.If you are testing the resistor pack, yes, disconnect it from the 24v buss bar and from the GP relay. Measure the resistance from one side of the resistor pack to the other. One probe on each end. The resistors are connected in parallel. You measure both at the same time, not individually.
In theory, you should measure only the resistor pack, not the leads going to and from the resistor pack. If you can reach the point where the lead connects to the resistor, do that. If not, measure from the 24v lead (once its disconnected) where it would normally connect to the buss bar, and to the other lead's end where it connects to the GP relay. If it's all good, that should be close enough. If the reading isn't correct, you'll need to make the effort to measure only the resistor pack without the leads in order to find where the problem is. There could be a poor connection in one of the leads, for example. Corrosion creates resistance. If the resistance anywhere on that path from the 24v buss bar to the GP is higher than normal, you'll get less voltage at the GP, meaning it won't get as hot as it should.
To test the GPs, there is no need to mess with the resistor pack. Just measure each GP individually:
- Disconnect the GP connector at the GP. This is a straight pull away from the GP.
- Connect one probe of your meter to a good ground location. The intake manifold, for example. Make sure you have a solid, clean connection.
- Touch the tip of the other probe to the tip of the GP where the wire normally connects.
- Read the meter.
- Write down your reading.
- Reconnect that GP.
- Repeat for each of the GPs.
