Tie Rod End Removal
Computerdoc08
222
Florida
I am trying to replace my tie rod ends during a front axle service and I cannot get it to come off. I tried a 14 inch pipe wrench as noted in the TM I attached, but maybe I’m not placing it in the correct place to get enough torque.
I’ve hosed it down with Pb blaster numerous times as well.
Any suggestions?
Thank you
chucky
19,364
TN .
If its really hung in there get ya a propane torch and heat just the coller that tha tie rod is stuck thru and not the tierod turn your nut upside down and put back on the threaded part and hit it with the hammer while impacting the tierod with the forked impact gun should get it !
Computerdoc08
222
Florida
I’ve removed the tie rod end from the knuckle. I’m not able to get the tie rod end to budge using a 14 inch pipe wrench. I can try some heat.
tommys2patrick
391
Livermore, Colorado
if you are still having trouble, you might slip the tie rod end back on the knuckle and loosely run the nut back on so it doesn't wiggle around. then put the pipe wrench on the tie rod itself some where near the middle. then use a floor jack on the end of the pipe wrench. that way you can use the weight of the truck to help you. reverse directions a couple times and then use the jack. it should unscrew both ends of the tie rod at the same time. a little back and forth should loosen both at once. before you do this you might use something to mark the tie rod and both ends before separating everything. it may also help to count exposed threads on the tie rod end so when you install the new ends you will know how far to screw them in.
Computerdoc08
222
Florida
I could not get the ends off the rod, tried larger pipe wrench, heat, multiple sprays banging with a hammer to break loose some rust…. No luck. I ordered a heavy duty tie rod from Boyce and used NOS tie rod ends. I’ll play with getting the ends off the old tie rod when I have some extra time. Steering is really improved now.
