Abbylind
- 16
- 18
- Palm Harbor FL & NM
Ignition senor!
I need to check but I'm pretty sure I just plugged it into an "IGN" slot in the fuse block. I haven't had any trouble so far.Tiny Tach directions say to power it from a circuit that is turned off while starting, to protect it from voltage surges. I've been poking around with a meter and reading wiring diagrams. Is there a CUCV circuit that powers off during starting? (Radio circuits do this...)
I just hit the sensor with blaxk spray paint. Its been good so far
As a project I wanted to carry out for while I'm going to fit a military rev counter to my Gamma Goat, the gearbox goes in to the correct fitting on the drivers side of the engine just below the filter. And I will try to use a deuce cable.Ok wow, you are getting to what I have been looking for to put in my gama goat, which has a 3 cyl diesel. Can you tell us a little about this tiny tach, how many cylinders, model #'s ect.. I think you have a good number of us paying attention!
