Trailer for HMMWV
dilvoy
25
San Francisco, Ca.
My M101A3 has the same track and ground clearance as the Humvee, because of the design of the axle that is used and it has cool wide fenders to cover up the tires too. It will attach to anything that has the Mil standard Pintal Hitch.
emmado22
171
Mid Hudson Valley NY
M101A3's were made (converted from m101A2's actually) for the HMMWV as a cheap interm replacement while the HMT/LTT/what was later adopted as the M1101/M1102 series of trailers went thru it's rather painful inital development and production run and "do not use" orders...
greensix
Miamisburg Ohio
I have a silver eagle m1101 with top only weights 1460lbs and can haul 2000lbs. The nice thing is unloaded you can grab the pintle eye and move it around yourself. There has been a series of mwos as the different generations have come along. Being aluminum there is no rusting and comon parts interchange with hmmwv lights,tires,shocks
emmado22
171
There is only one generaltion M1101/M1102 series trailer.
Do you have all the MWO's done to your trailer? There are 3 of them total that need to be applied to the Silver Eagles, all safety related. The Shutt's are all good to go, as they were awarded the contract after the MWO's came out.
