Toolslinger
- 548
- 93
- PA
I've been wanting to put a trailer under my MEP-802a. It hasn't been an urgent need, so I really didn't pursue it. It still isn't urgent. However, I had the thought that it would be very nice to put the 802 on one end of a trailer, and a vintage pretty heavy, but low power draw air compressor on the other side. Compressor is about the same size as an 802, but probably only 400# or so. I've seen the twin generator trailers, but never looked in to what model that was. Weight would be fine on an M116, but I don't know about deck space, that seems like it might be too small to fit both units. This setup isn't going to see road use, just movement around my property to provide power, and air when something breaks down, or I need to blow out irrigation.
With that in mind... A) did they squeeze 2 generators on a 116? B) if not, what trailer did they use? C) what other model should I at least be considering so I know what to look for in my casual internet searching/research?
