Tranny Flush
kurtkds
-1
Great Falls MT
So name your favorite flush method.
I changed my gear oil in my tranny on the Deuce a couple of weeks ago, and put in MobilHD plus 80W-90 that conforms to the MIL-PRF-2105E standard.
Soon after I changed the gear oil I noticed that when I would shift into 4th gear, the syncro's were really stiff and If I didn't take my time shifting the gears would grind. I didn't have this problem before I did the oil change. Once the tranny warms up or after a few shifts the syncros' loosen up and things shift like normal.
So I'm looking for your advice.. I saw the post about dextron 3 ATF. What about Diesel or Kerosene?
And after I'm done flushing, I'm thinking about synthetic.
Like Mobil 1 Synthetic Gear Lubricant LS 75W-90.
Any thoughts??
wsucougarx
114
Washington State
I was told to AVOID synthetics at all costs b/c the synthetics are so thin that it doesn't climb the gears to lube the upper portion of the tranny. Thus causing tranny failure. Not sure if that's true or not but I'm not going to venture to find out;-) I've heard of letting kerosene sit in the tranny w/out driving to help flush it out, then putting gear oil in, drive it around the block, drain, and refill
2Deuces wild
calif
Dextron has 10 times more detergent and has lube quality's that kerosene doesn't.
Just let it run around in the case with the transfer in Neutral no driving needed. Good old 85-90 is just fine for our old steele.
m139h2otruck
NH
Had to flush the transfer case on the water truck due to the sprags sticking. Used fuel oil and ATF 50/50. Just drove it back and forth and slowly around about 1/4 mile, then drained and refilled with std. GL-5 from Sam's or Tractor Supply. Has worked OK since. Drained flush was very black and dirty!! If you do this, just don't go very fast or apply too much load to the transmisson.
