Transfer Case/Transmision Housing
cten
Georgetown/MA
I have not taken the time to read the manual yet on this section.
Does the transfer case and the transmission both take GL1?
I should do a search on these two items also.
Thanks,
cten
Georgetown/MA
Is it the same as replacing the gear lube in the differentials?
Just pop the two plugs, drain and then replace the lube up to the vent.
Or is there something special?
Any idea on how much lube is needed to do both?
Regard,
Armada
Buick City, MI
"Just pop the two plugs, drain and then replace the lube up to the vent."
They are filled about level with the fill hole (the plug roughly half way up from the drain plug), not the vent. Otherwise you would be venting lube instead of air.
