UPFINN
- 4
- 18
- Ishpeming Michigan
Over the past few years my truck has been pulling to the right. It seems to be getting worse, but is hard to tell.
I did a alignment and found that the front was toed in 3/8, so I put it back to 1/8. I also changed out the right front tire to one with less cupping and more tread. The left front tire is nearly new titan T-Hawk, while the left is a older Goodyear. The previous tires were Denman.
Took the truck for a drive today and the problem was still there, maybe even worse! You let go of the wheel and it will start heading for the ditch. The steering wheel is always pulling.
I jacked it up and used the pry bar under the wheel and didn't seem to notice any movement. So I doubt it is tie rod ends or king pin bushings.
What else could it be? Wheel bearing, older tire (tread depth is matched between left and right), king pin bushings, shocks?
The next thing I could try replacing are the shocks, but can't tell if they are bad. Is it normal to be able to compress them by hand? When I loosen the bolts that hold them they contract by themselves, and I can press them down more. They also look like the original shocks.
If it is the king pin bushing, well I might just keep driving it. It looks like a pain to replace and the new bushings are not as good as the old. The process may also involve machining a grease groove and using a press to size it. I do not have the equipment.
I am going to take off the front hubs to repaint and grease bearings. I'll see what I can find.
