under dash body harness
tanhmmwv
ma
could anyone please photos or TM info showing the correct routing of the body harness from above the accelerator pedal routing behind the steering column.
mine has to be installed incorrectly as it was chaffing on the steering column at the u joint. see photo below....
thanks in advance!
tanhmmwv
ma
finally had some time to look into the wire chaffing and difficult steering issue....
found that I installed this bolt backwards.
The head of the bolt was hitting the column U joint.
it is installed correctly now. no more difficult steering.
