Billy Bobbed
- 13
- 38
- Terre Haute,Indiana
I was trying to keep my cables to the right and to the bottom.BC the diagram really helped THANKS.
Its the MX-6707 antennas,dont know if it all works right yet.The antenna clicks when I change some of the stations on the RT-524.And when I hold the mic or the radio on the headset the fan on the RT524 really gets fast.Still trying to figure this whole thing out.I found out one of my new MX-6707 antennas does'nt click when I change channels,so I use it for the R442 radio.Hmm, you've got your R-442a/VRC hooked upto a MX-6707/As-1729 setup? Does it receive OK?
I guess I need to check on this,it uses the same coax cable as the rt524 CG-1773.OK, I haven't seen the MX-6707 hooked up to an R-442a/VRC just yet. I'm use to seeing the AB-15 w/MS-116a, MS117a, and the MS118a used.
Sounds like it's working properly. The 'clicking' from the antenna is the auto adjustment of the frequency range.Its the MX-6707 antennas,dont know if it all works right yet.The antenna clicks when I change some of the stations on the RT-524.And when I hold the mic or the radio on the headset the fan on the RT524 really gets fast.
Oh forgot to mention, your setup looks outstanding!Its the MX-6707 antennas,dont know if it all works right yet.The antenna clicks when I change some of the stations on the RT-524.And when I hold the mic or the radio on the headset the fan on the RT524 really gets fast.Still trying to figure this whole thing out.I found out one of my new MX-6707 antennas does'nt click when I change channels,so I use it for the R442 radio.
Nice, well thought out install
