Isaac-1
- 52
- 48
- SW, Louisiana
I had my MEP-016B running some this weekend, after changing the voltage selector switch to 120V only from 120V/208V I find that my front panel voltage control knob will now only adjust up to 117.4 V (in 120/208 it would go up to 125V or so), I was wondering if anyone knows if there is a simple trim pot on the voltage regulator to adjust the range of the front panel knob? I think the MEP-016B uses the same volatge regulators as most of the other small MEP units. I think there is an adjustment procedure in the TM for the voltage regulator, but don;'t know if I need to go through the whole process or if I can just tweak one thing.
Thanks Ike
Thanks Ike
