HDJ81MAX
- 18
- 3
- Homestead, Florida
I will be installing two new wellnuts. The question i have is do you guys put telfon tape?
Great memory! Yes, the inner thread is 1/4-18 NPT (National Pipe Taper) taper thread.Its been a fair few years since I did the swap on my machine, but I think the threads were tapered, eliminating the need?
That being said. No telfon correct?Great memory! Yes, the inner thread is 1/4-18 NPT (National Pipe Taper) taper thread.
All the best,
2Pbfeet
You are braver than I. I've never had a tapered thread seal properly without some form of sealantNo teflon. The taper will seal the threads. There are instances where tape/dope is needed in a tapered thread application, but its not this one. This is not a pressurized fitting, just static pressure from the fuel.
I most only use this sealant. Little expensive but worth every penny (or since Bidens inflation 2 penny's). Also neverseze every where else.I use locktite 567. It's a thread sealer
