I installed the new Temp gauge. I got the part from the dealer some time ago; but did not install it until today.
The Temp gauge went smoother than expected. I had already installed the gauge in the dash alongside the ammeter/voltage meter. To complete the install, I cut a gasket to match the bolt-on bung for the new temp probe. When you do this, I recommend disconnecting the connector that comes from the firewall into the main harness right above the new temp gauge location. The bring all the wires forward as far as possible to allow wrench access. The stainless line- I think it's the one that runs off the back of the engine to the transmission modulator, is directly in the way- a gentle pulling and bending will move it enough for you to get the job done. You'll need a 9/16" Deep Socket, a gasket scraper and the new chevy part and gasket. The part numbers for both are elsewhere in this forum. Bung from GM, gasket from NAPA.
Question, where should the gauge read for temp? I drove for 10-15 minutes in 90 degree heat today, and the needle barely went to 140 °F. !?!
