- 167
- 174
- 43
- Los Angeles/CA
I have a 6.2 with 6.5 turbo in my M1009. I have a gear drive timing set and fluidamper that have been sitting in my garage for years and I am finally going to install them, and fix my front crank seal oil leak while I am in there. I have some questions for things I could do while the frint of the engine is apart and I'm curious what y'all think:
Obviously I have to take the water pump and timing cover off to get to the timing set. The water pump is 4 years old and doesn't leak, but was a cheap $50 unit from Rockauto. I have occasional overheating problems when climbing steep highway grades when its hot out, and at high load offroad (think deep sand). The truck runs fine climbing grades in cooler weather or even when 100+ F if just cruising down the highway. I dont necessarily think the water pump is the problem, but its going to be off anyway. Does anyone have experience with Flowkooler or other "high output" water pumps? Is there any sort of water pump that is an effective upgrade over a stock type, or is it snake oil and they're all the same?
I do want to get a better radiator, and I think this is the key to solving my cooling problems. I currently have an aluminum rockauto radiator with a 1.75" core thickness. I would like something with a 2.5" or thicker core (dont really care how many rows, as aluminum radiators seem to have fewer larger rows resulting in the same core thickness and same cooling performance). Does anyone have a radiator they have had good luck with and would recommend?
I also have a GM1 turbo, which I understand has a fairly restrictive turbine housing and exhuast outlet. I'm running ~6psi and I am very happy with the trucks power and performance. The turbo is in good shape with no shaft play. It cruises 75 mph on the highway with power to spare and I like how fast the turbo spools up when off road. However I wish the EGTs were lower (can get up to 1100F+ if I try to hold 70 mph climbing highway grades, and I have to back off the throttle to get it back down tunder 900F) and I wonder if a less restrictive turbo would help with MPGs. I am getting ready to build a custom exhaust, so if I am going to switch to a different turbo now is the time. There's an overwhelming amount of info on turbos for these trucks out there, and I'm hoping others can chime in and point out anything I might have missed:
- ATT - non wastegated, probably wont spool fast enough for me off road at high elevation?
- GM4, 5, 8 - maybe slightly more free flowing than a GM1, but worth replacing if the GM1 is working fine? Maybe for a GM8?
- HX35 - seems like overkill for a stock compression engine that I'm unwilling to run above 7 psi of boost.
- HX40 - definitely overkill
- anything else I am missing?
