XM708 refurb
JimC2
255
Collierville TN
The dump bed is compatible with a 6" wood height extension. I'm thinking two red oak 2x8s 6 feet long cut to 6" width.
Any thoughts?
G744
4,391
Hidden Valley, Az
Looks to me you have side risers with channels to accommodate the boards.
If not, maybe there are reinforcements in the bed sides that would accept stakes that could be fastened to the boards.
G744
JimC2
255
Collierville TN
"Looks to me you have side risers with channels to accommodate the boards".
I don't. The side risers don't have channels.
I'm going to spot weld 4 six inch long 1.625x1.625x1.625 steel U-channels vertically at the front and rear corners of the risers to receive 6 foot long red oak 2x8s ripped to 6 inches as drop in sideboards.
m1010plowboy
3,063
Edmonton, Canada
Found another picture and it looks like the board is on the inside of the back post. There is not a lot of info out there but somebody somewhere would have put a TM together so they could later bark, 'Why didn't you read the TM"? If I come across more details I'll get them up here. This is a cool picture with Frank mentioning """" note from the Patton museum indicates XM708 only one of the series to have power brakes """
Looks like you might have power brakes!
https://www.steelsoldiers.com/threads/small-dump-truck-vietnam-era.164076/#post-1969659
Started peeling through the TM's over here but haven't found details yet. XM708 is not mentioned in the operators manual. There must be one out there.
JimC2
255
Collierville TN
Well, I blew my intended schedule for this week, but yesterday I did get two sideboards of Apitong hardwood that is reputedly 13% harder and 26% stronger than oak (usually used for flatbed trailer floors). It is an attractive reddish brown color and a full 2-1/8" thick.
I'll give it a light sanding and a coat or two of clear polyurethane for protection.
JimC2
255
Collierville TN
Ordered two more 1050x16 directional tires, tubes, and flaps today, for a total of four. Gotta get the rims bead blasted and painted.
JimC2
255
Collierville TN
Looking forward to getting the new tires mounted. Narrow 9" tread width and 38" height.
And I'm starting to think about also refurbing my 37, starting with the same tires.
JimC2
255
Collierville TN
Here's a preliminary image of the tailgate I'm going to build this fall. It still has several errors, but the most critical are the horizontal measurements between the inboard side of the 12ga upright braces at each end of the gate (marked Lt and Lb in red on the drawing). I've drawn the inboard side of these braces vertical, but I believe they are actually tapered on some tailgates (my dump bed is a Gar Wood).- some photos of the braces seem wider at the bottom than the top.
Could any of you guys who have access to a tailgate check those two dimensions for me?
Thanks,
Jim Cunningham
Cunningham Engineering Assoc
Collierville, TN 38017
JimC2
255
Collierville TN
Lost the keys to my hangar a couple of months ago when I totaled my car and broke my shoulder. Going out to the airport today to cut the lock off and gather up my NOS windshield frame for the 708, soft top frame, extra lug nuts, rear axles, and some misc. other stuff.
BTW, one of the illegible designators on the front bumper appears to have read "IS9GP", but that's still a bit of a guess. The "S" is an upside down stencil "2".
JimC2
255
Collierville TN
Tore the passenger side rocker panel off my newly painted car at the airstrip gate while driving to my hanger. Arrgghh...
Found the soft top frame, a passenger side running board, three doors, two rear axles, four 37 tailgates. Haven't found the windshield outer frame yet. It may be in my garage at home.
JimC2
255
Collierville TN
Didn't find the windshield frame yet, but I did find the towbar I built to fit my 37, 708, and 1955A T-Bird (I have to pull the front bumper to attach the Bird). As an aside, the 37 was my first vehicle - given to me in 1962 - and was my daily driver for several years. The T-Bird was my first car, in 1965.
Got some media for the sandblaster and will be cleaning up the rims next week prior to mounting the new tires on the 708.
JimC2
255
Collierville TN
I think I'm going to implement 3 variations on my tailgate.
1) the section of the rectangular brace along the top is 2.5"×2.75", which isn't commercially available. I don't want to scratch build it and plan to use a commercially available 2.5"×3" rectangular tube instead.
2&3) I doubt that I can adequately control the radius of the bends in the plates for the side verticals and the horizontal plate that encapsulates the 1.125" horizontal shaft at the bottom. I currently plan to do the radius with a commercially available steel tube and weld on flat steel plates for the straight portions. They will look externally original.
