Parameters:
MEP-805
Voltage Setting 450-480
HZ Setting 60HZ
Load 60% 20KW continuous and 4 1.5Hp motors intermittently Max Load always less than 25KW
Issue:
Generator starts to produce power and stays steady at 60 HZ and adjust automatically as it should. After 15 min to 2 hours it will occasionally drop to 52 HZ and can not be manually adjusted up to 60hz. Occasionally it mysteriously comes back to 60hz on its own. Also, when this happens, if load is taken off line by opening circuit, hz rise to over 60hz. It seems like generator just stops controling engine rpm hence hz is unstable. Sometimes shutting down unit and restarting will get it back to 60hz but not always. I am new to this site and new to this MEP-805. Any help will be greatly appreciated. Also does anyone know of a place where I can call who supports these MEP Generators. I have 3 and it would be helpfully to know where to get service.
Thank You
MEP-805
HZ Setting 60HZ
Issue:
Thank You
