- 435
- 883
- 93
- Mansfield, PA
My bad. What is the cost difference between yours and the Gardico gasket ?Sir, you are incorrect. This gasket was copied from the Gardico kit gasket using a 3 D scanner. Then it was cut on a CNC router with a knife head attachment. I'm guessing we're within +/-.010" from the Gardico. We also had an NOS gasket for comparison. Guess what? Looks just like the aftermarket gasket.
Kit Gasket:
NOS Gasket:
And, to top off the conversation, cover the uses said gasket. Zoom in and you can see the gasket outline:
Guy
I talked about this with the "Gardico" engineers. That is why they used the material they did. It stands up to gasoline, diesel, oil, water, and heat. Also, if your careful during disassembly you can reuse the gaskets. I spent about 6 months going back and forth to Gardico bringing in parts I cleaned up to get scanned and "fabed" up until we got the finished product. The end product was more money than I wanted it to be, but that was out of my control. Many friends asked why I didn't just sell the gaskets myself and make some profit out of all my labor. I just felt it was better for the "collector" community to have this resource then keep it to myself. That way even after I pass on or leave or whatever people can still buy gaskets for their transmissions.The one recommendation I have is that if this is a water side gasket to use a material with an SBR binder instead of NBR. Palmetto doesn't offer this. Garlock 3200 would be a better option.
The Palmetto 2970 you're using is the equivalent to Garlock 3000 if you want to make the comparison.
