euclides5370
- 4
- 8
- walnut creek ca
just bring from the auction crank but wont start l,oos like a fuel problem, i dont hear the pump working filter is not getting diesel at all sameone know whats the fuse number for fuel pup
Is that an ecm error code? Not sure what module that is from.
Yea looks to be from the TIM module indicated by the test code. Truck has to be running for that test to be accurate.
Yes you have to hand prime the engineNo diesel is going to the engine there is diesel on tank but not filling up the filters
If the water temp gauge is going up and down then ecm is not sending any signals to the gauge cluster.Is that normar when i have keys on position, psi gauge goes up and down with the water too
So what's that means bad ground ?If the water temp gauge is going up and down then ecm is not sending any signals to the gauge cluster.
Comm wiring. Not important.They cut some wires and I really don't know what's is maybe is that ..I check every place is possible no idea 1 is ground other is positive I'm. Ot sure with was for like a winch or something ?
No. Ecm is dead or not getting power. Check voltage with key on to pin 70 on ecm rear connector. 4mm Allan key to remove connector.So what's that means bad ground ?
