MTVR turns over but won't start
aw113sgte
1,481
La Crosse, WI
I believe loast the information from the ECM when I connect the ET from cat is asking me to flash the ECM does someone have the files
If it sees the ecm that's really good news. The older ecm configurations could loose memory when the battery failed. Newer flash files hard write that needed info.
Demilitarized has the needed files on his site. Watch some YouTube videos on the process.
You'll want to get the injector codes programmed at some point (written on the injectors)
euclides5370
walnut creek ca
shit my cat et only was able to see the ecm couple times so i decide to flash and im not sure with i did right was kind stupid of me
DeMilitarized
1,219
Gainesville, GA
The correct files are on my website southeastmilitaryequipment.com/mtvr
Configuration file may need to be flashed but be sure to flash the stock 410hp tune first and then set up config and make sure you have cat password generator for 10 digit.
euclides5370
walnut creek ca
Just a update I find out was my ECM was bad now I'm trying to figure out the cheapest way to fix ...I appreciate the help from everyone here I keep u guys updated, my ECM was. Not reading right ..
