The rear condenser units on my M1165A1 are loose, not being held up by any bracket. Anyone know what parts are missing to secure it?
Here's a video of the issue.
IIRC the bracket is built into the condenser, it is held in at the rear by some screws through the top of the fender near the back.
Actually it can be removed from the cond. but it could still be there and all you need are the screws, notice different part numbers for the left or right side bracket.
It looks like the later trucks had that bracket riveted in place as there are no holes for the bracket, if it had screws they would be at C and D of second picture
Yes and notice there is a right and left side, IIRC when I installed my condensers in my M998 I ended up getting some aftermarket brackets
If you will notice the replacement is better built than the original you had.Got em installed and good to go. As DREDnot described above, it’s a goofy design. Rear lip of condenser rests on the ledge of the brackets. Only a matter of time before it slips off, or the bracket breaks again.
Here’s a pic showing the mounting bolts. Note the new bracket, compared to what’s left of the old one (attachment points only)!
Thanks all for the help.
