New to m211
NDT
7,930
Camp Wood/LC, TX
Looks good! Do you have it apart for paint or do you need parts to put it back together?
If you use silicone brake fluid, the stock wheel cylinders will be fine. You have to be careful with the REB, as I understand it, if you are going 55 mph and someone shifts to 1st, it will do just that. Once you get used to the stock hydramatic, I think you will find it’s ok.
jeff gardiner
23
Richland Wa
Thank you for the tips..i do have a fiberglass full top but would be interested in a folding front windsheild with hard or soft top. I look forward to actually taking it for a drive once i get the brakes up to par
jeff gardiner
23
Richland Wa
Hey there,
My name is Jeff Gardiner and i have heard you are the man to ask about my m211 auto trans. I am new to this truck. I checked the dipstick in the floor that i assume is for the trans and it was milky white. Obviously i will change the fluid but wanna find where the contamination occured so i can fix problem.. you have any tips or advice? Thanks for any help
Jeff
G744
4,390
Hidden Valley, Az
In the '50's, when the G749 trucks were front-line the military spec'd 10W rather than ATF as it was already in the system. Auto transmissions were not as popular then. Not that it was better, as they found out about running Detroit 2-cycles with OE30 in the crankcase rather than straight 40 DELO. Lotsa' motors coked up and died from that.
G744
rustystud
3,487
Woodinville, Washington
It's water from the engine. Sad to say your clutch plates might be toast, and you might have a lot of rust in the transmission. The HydraMatic transmission uses engine coolant to cool it. They have a tendency to run hot. VERY HOT at times. So the engineers decided to use a simple method of heat transfer using the engines coolant system. Works great until it doesn't. Usually the Oil pan cracks allowing the coolant to mix with the transmission oil.
Now if your lucky, the water in your transmission came from someone trying to "ford" your truck across some water. Lucky because your oil pan will be intact. Once they are cracked there is nothing you can do but toss them. Last year alone I tossed 4 away. Makes you kind'a sick to do so, but there it is.
So the first thing you need to do is drop your oil pan and check for cracks. Look back on my rebuild and see where I show you what to look for.
Second, if the oil pan is OK, then reinstall it and add new fluid and run it a short distance. Then drain out the oil and refill it with new oil again. I know this is expensive, but you need to clean out the gunk the water makes and any rust that is loose on the parts. Especially needle bearings.
Then if all is OK, go and enjoy your truck !
Like Reply
Report
[IMG alt="rustystud"]https://www.steelsoldiers.com/data/avatars/m/32/32597.jpg?1575779013[/IMG]
Remove formatting
BoldItalicUnderlineStrike-through
Text colorFont familyFont size
Insert linkInsert imageSmiliesInsert
AlignmentListInsert table
UndoRedo
DraftsToggle BB code
rustystud
3,487
Can of worms question, that has been debated here forever, either Dexron ATF or engine oil per the lube order.
Actually I posted what GMC said in there HydraMatic division about transmission. Only use ATF .
We know why the military used it, doesn't make it right though.
Also ATF is more than just 10W oil with additives. The whole "coefficient of friction" is totally different than regular oil. Plus all the additives ! ;)
jeff gardiner
23
Richland Wa
Like Reply
Report
Remove formatting
UndoRedo
I plan on checking the pan out in the next couple weeks...hopefully no cracks..will keep u updated
Thanks jeff
