jeff gardiner
- 23
- 3
- Richland Wa
Thank you for the tips..i do have a fiberglass full top but would be interested in a folding front windsheild with hard or soft top. I look forward to actually taking it for a drive once i get the brakes up to parLooks good! Do you have it apart for paint or do you need parts to put it back together?
If you use silicone brake fluid, the stock wheel cylinders will be fine. You have to be careful with the REB, as I understand it, if you are going 55 mph and someone shifts to 1st, it will do just that. Once you get used to the stock hydramatic, I think you will find it’s ok.
I plan on hopefully painting it back to original color..hopefully this winterThank you for the tips..i do have a fiberglass full top but would be interested in a folding front windsheild with hard or soft top. I look forward to actually taking it for a drive once i get the brakes up to par
Do you mean keep them away of just the hydramatics ? Or are you also saying stay away from putting rebs in M34, M35, M49C etc too?I would stay away from any REB kit.
ATF is simply 10 wt engine oil with special additives. My GMC has ATF in it since the 1970,s. No issues.Will atf hurt any of seals if they are oem...would i be better off with oil option?
Actually I posted what GMC said in there HydraMatic division about transmission. Only use ATF .Can of worms question, that has been debated here forever, either Dexron ATF or engine oil per the lube order.
No problem. We all just need to work together. Makes life easier for everyone.Thanks Greg. You know what for!
I plan on checking the pan out in the next couple weeks...hopefully no cracks..will keep u updatedIt's water from the engine. Sad to say your clutch plates might be toast, and you might have a lot of rust in the transmission. The HydraMatic transmission uses engine coolant to cool it. They have a tendency to run hot. VERY HOT at times. So the engineers decided to use a simple method of heat transfer using the engines coolant system. Works great until it doesn't. Usually the Oil pan cracks allowing the coolant to mix with the transmission oil.
Now if your lucky, the water in your transmission came from someone trying to "ford" your truck across some water. Lucky because your oil pan will be intact. Once they are cracked there is nothing you can do but toss them. Last year alone I tossed 4 away. Makes you kind'a sick to do so, but there it is.
So the first thing you need to do is drop your oil pan and check for cracks. Look back on my rebuild and see where I show you what to look for.
Second, if the oil pan is OK, then reinstall it and add new fluid and run it a short distance. Then drain out the oil and refill it with new oil again. I know this is expensive, but you need to clean out the gunk the water makes and any rust that is loose on the parts. Especially needle bearings.
Then if all is OK, go and enjoy your truck !
Like Reply
Report
[IMG alt="rustystud"]https://www.steelsoldiers.com/data/avatars/m/32/32597.jpg?1575779013[/IMG]
Remove formatting
BoldItalicUnderlineStrike-through
Text colorFont familyFont size
Insert linkInsert imageSmiliesInsert
AlignmentListInsert table
UndoRedo
DraftsToggle BB code
