MTVR ECM Configure File
euclides5370
walnut creek ca
I try everything so far like priming fuel truck won't start ,cranks really good runs on ether but stop after , everything looks good ,compression, I try to connect the cat et to ECM and looks like was gone so I try to flash and did flash but still can't connect right ..
JonM934
258
Herriman UTAH
Do you get any codes?
I seem to remember someone offering to 'rent' a good ECM for troubleshooting. . .
I have an ECM that will work to troubleshoot. The problem with it is that once you turn off the truck for a while it loses the configuration because the battery inside is bad.
Jon
DeMilitarized
1,219
Gainesville, GA
Leave the truck keyed on for a while. See if connection becomes less speraric.
aw113sgte
1,481
La Crosse, WI
Okay, so it's good news you can talk to the ECM, that also shows you have/had the OLD flash file that could cause start issues. See here: https://static.nhtsa.gov/odi/tsbs/2020/MC-10177116-0001.pdf
After flashing did you load the config file? The truck has to be told all the settings to run (the flash is just the "tune" but lacks the specific information for your truck.
Seems like you are having connectivity issues, but the fact you were able to successfully load the flash? Doesn't make sense that ET (not winflash) can't read it unless your connection settings are a bit off. Could also happen if you a flaky protocol adapter - there are lots ofknock offs out there.
euclides5370
walnut creek ca
I think Is dead now I was able to work but very strange decide to die not showing at all after I put the file for 505 and the work so I try to go back stock and after die not showing anymore
What's kind ECM can I replace have to be exactly c12 ecm or can be other model since I will flash
DeMilitarized
1,219
Gainesville, GA
Has to be a very specific ECM. If you have to ask it is likely you should not be programming your own ECM. Severe engine damage will occur and can also cause transmission damage. I recommend honestly to get a drop in replacement ECM for your truck pre programmed and configured. I do sell them this way so if interested let me know. I can also do a proper attempt to flash your ecm.
