MAdams
- 155
- 43
- San Dimas, CA
Sure I'll throw a stamp on it and drop it in the mail today
Your best bet is probably to post up a detailed question, you'll find many people very willing to help. It's almost always very difficult to diagnose over a phone.Can sameone understand about this stuff give me ring a?
Leave the truck keyed on for a while. See if connection becomes less speraric.I try everything so far like priming fuel truck won't start ,cranks really good runs on ether but stop after , everything looks good ,compression, I try to connect the cat et to ECM and looks like was gone so I try to flash and did flash but still can't connect right ..
I will try that I check the pins on the connector everything looks good the 24v and the ground onesLeave the truck keyed on for a while. See if connection becomes less speraric.
Has to be a very specific ECM. If you have to ask it is likely you should not be programming your own ECM. Severe engine damage will occur and can also cause transmission damage. I recommend honestly to get a drop in replacement ECM for your truck pre programmed and configured. I do sell them this way so if interested let me know. I can also do a proper attempt to flash your ecm.I think Is dead now I was able to work but very strange decide to die not showing at all after I put the file for 505 and the work so I try to go back stock and after die not showing anymore
What's kind ECM can I replace have to be exactly c12 ecm or can be other model since I will flash
